Hot
New
Out stock
xTool D1 Pro 10W : Higher Accuracy Diode DIY Laser Engraving & Cutting Machine
$699.99 $849.99
You Save: $150.00
Metal Grey
Golden Red
D1 Pro 10W
$699.99
$849.99
    D1 Pro 10W + RA2 Pro
    $959.99
    $1,148.99
      Icon/Attributes/Free shipping Arrives Before Christmas
      Shop with Confidence
      icon-theme-126 icon-theme-161 icon-theme-138 icon-theme-027 icon-theme-022
      Secure Payment
      12-month Warranty
      Free Shipping
      30-day Return & Refund
      Pay with Ease
      Pay Image
      Pay Image
      Pay Image
      Trusted Delivery
      Higher Accuracy DIY Laser Engraving & Cutting Machine
      Meet All Your Needs
      Working Speed
      Increase Your Productivity at the Highest-Speed
      With the upgraded algorithms, the routing speed can reach up to
      400mm/s
      Structure
      ALL-Metal Made,
      All-Time Accurate
      Aluminum Plates & Steel Timing Pulley and Shafts
      Eliminate Machine Vibrations by Tightening Up the Synchronous Belt
      *First Designed and Used by xTool
       The solid STEEL stabilizes the structure, allowing for:
      engraving/cutting accuracy to reach 0.004 inches
      repositioning accuracy down to less than 0.007 inches.
      Focus Adjustment
      Easily and Precisely Adjust the Focus
      Fix the Focus
      Pull down the focal length setting bar, and adjust its distance to the material by sliding up or down the entire laser module
      Limit Switches
      Limit Switches Auto-Identifying Boundaries in All Directions
      Limit switches on both the X and Y axis can accurately locate the working coordinates of the laser head, updating you on the processing progress in software.
      They will also trigger the alarm if the laser head is about to hit the boundary of the machine.
      Color Engraving on Metal
      Invigorate Your Creations with 340+ Colors
      *The color varies from different materials in different environments on different parameters.
      Super powerful 20W laser beam oxidizes the metallic surface in an instant, bringing vivid colors to the engraved metal.
      The color of the metal engraving will no longer be limited to black/grey. Your creativity will be brought to the next level with 340+ colors.
      Safety Features
      Instant Stop Processing for Extra Safety
      Instant Stop when machine detects flames
       Instant Stop when machine is moving or tipping
      Software
      Compatible with Software of All Levels
      Quickly Started with xTool Creative Space
      Updating Project Files
      Image Editing
      Batch Processing with Circular Array
      Default Working Parameters for Materials
      Compatible with mature engraving software: LightBurn
      The layout, editing, and control software for common laser cutter. Engraving file format supports NC, BMP, JPG, PNG, DXF, etc.
      xTool RA2 Pro
      Versatile Cylinder Engraving
      RA2 Pro (Sold Separately): The WORLD'S FIRST 4-in-1 Rotary for laser Engraver, suitable for irregular cylinder and sphere objects, like tumblers, mugs and rings
           · Roller Rotary      · Chuck Rotary         · Sphere Rotary      · Ring Rotary
      Functional Designs
      Details Matter
      Minimize Lens Pollutions by Optimizing Air Outtake
      New structural design of the light shield prevents laser lenses polluting by smoke and reducing dust accumulations inside the shield.
      Large Engraving Area
      A large working area of 430*390 mm ( 17*15.4 inch ), more than the size of A3 paper, allows you to engrave more patterns at once. Easy to use and more efficient.
      The Risers
      Use additional risers (sold separately) to increase the height of xTool D1 Pro to facilitate the engraving of higher objects(use 2 sets to increase height to 140mm). Customize your skateboard or basketball to make them cooler.
      Just Connect
      You can transfer data via Wi-Fi, USB cable, a large capacity TF card (Offline Use) and use D1 Pro anytime and anywhere.
      Just Connect
      You can transfer data via Wi-Fi, USB cable, a large capacity TF card (Offline Use) and use D1 anytime and anywhere.
      Specs
      TypexTool D1 Pro-20W  xTool D1 Pro-10W
      Machine Power120W60W
      Laser Electric Power84W40W
      Laser Module Output Power20W10W
      Laser Spot0.08*0.10mm0.08*0.06 mm
      Routing Speed400 mm/s 400 mm/s
      Working Area 430 * 390 mm (16.93 * 15.35 inch)430*400 mm(16.93*15.75 inch)
      Max. Workpiece Height50 mm (2 inch)50 mm (2 inch)
      Max. Workpiece Height with X risers  50mm+X*45mm(each set riser height column)50mm+X*45mm(each set riser height column)
      Connecting InterfacesUSB/Wi-Fi/TF CardUSB/Wi-Fi/TF Card
      CertificationFCC / FDA / CEFCC / FDA / CE
      Operating SystemsWindows/macOS/Android/iOSWindows/macOS/Android/iOS
      Control SoftwarexTool Creative Space / LightBurnxTool Creative Space / LightBurn
      File Type(s)SVG/DXF/JPG/JPEG/PNG/BMP/TIF/CR2, etc.SVG/DXF/JPG/JPEG/PNG/BMP/TIF/CR2, etc.
      xTool D1 Pro 10W/20W VS xTool D1 10W/20W
      Table header 0xTool D1 Pro 10W/20WxTool D1 10W/20W
      Working Speed400mm/s160mm/s
      Compression Spot0.08*0.1mm0.08*0.15mm
      Working Area430*390 mm432*396mm
      Laser Head1. Suppot Focal Length Adjustment: Focal point can sink down to the middle of the thicker materials, to get better cutting results
       2. Optimizing the Structure of Air Outtake to Minimize Lens Pollutions
       3. Built in Air Nozzle (Air Pump Not Included)
      Limit SwitchesAuto-Identify 4 Boundaries Covered by 4 Limit Switches /
      Safety FeaturesTrigger the alarm and Instant Stop Processing, if the machine detects flames or moving/tipping/
      Part List
      $699.99 $849.99
      Request for Quote
      Quotation Notice
      1. An email has been sent to you containing the quotation file and all other important files. Please check your mailbox.
      2. The quote is valid for 30 days. Please generate your Purchase Order within this period. If the quote expires, a new quote will need to be generated.
      Download W9
      Download W9
      More Support
      If you need more help, kindly mail to vendor: us@makeblock.com
